1 Ton OTK Steering Kit
WAZZUXJ
Serious Offroad OTK 1ton steering. Was on Jeep for less than a year before I went to WJ steering.
Complete kit and knuckles available with inserts already welded. Worked great with 6" lift, I just can't leave well enough alone.
$200
splatvonzipper
$200
Damn, I just ordered my IRO OTK kit today. :(
WAZZUXJ
I just swapped out my Rusty's OTA track bar mount with the Clayton OTA track bar mount to better align my track bar with the WJ steering.
I will add the Rusty's OTA track bar mount to the sale.
WAZZUXJ
Someone will end up getting a good deal. I should probably take some pictures of the kit as it still looks like new.
WAZZUXJ
It is pretty close to a bolt in kit now. It came with inserts which required drilling knuckles and pitman arm 7/8". Since I swapped to WJ knuckles, I have the original knuckles already drilled and inserts welded, so just need to swap knuckles. Buyer would only need to drill out/ream pitman arm (insert provided).
Only other modification is relocation of track bar to over the axle, which I am including an OTA track bar bracket.
