boostamante
It's on CL right meow. Will consider lowering the price for fellow XJ owners.
http://losangeles.craigslist.org/lac/rvs/3207868155.html
Wondering how well this thing would drag around behind a lifted XJ. My kid would dig having this for surf trips.
This thing weighs a whopping 1330 lbs. It's not that heavy, though it would be nice to have breaks, the ones on my rig do a pretty good job at slowing it down. Disk brakes all around seem to hold up well.FWIW, I've dragged my 2001 Coleman Santa Fe (same size, maybe a big bigger,) from Chicago to Moab 3 times, twice with a 3" lift, once with a 4.5" lift. I had no problems with the trailer. Biggest problem with towing this is brakes, you *NEED* brakes on the trailer.
I'm pretty sure that replacement tenting is still available. Sounds like this one is priced to move.
That's quite a bit lighter than mine, by over 700 lbs. I do know that I wouldn't want to try braking mine down a 12% grade without trailer brakes behind an XJ.This thing weighs a whopping 1330 lbs. It's not that heavy, though it would be nice to have breaks, the ones on my rig do a pretty good job at slowing it down. Disk brakes all around seem to hold up well.
I'm trying to think how steep a grade i have on the Cajon pass, that being said, I don't think it's 12%.That's quite a bit lighter than mine, by over 700 lbs. I do know that I wouldn't want to try braking mine down a 12% grade without trailer brakes behind an XJ.
I couldn't tell you, all i know is that its a 1982 Coleman tent trailer, Niagara series.I'll bet a cup of coffee that it's got a Dexter axle under it, and if that's the case, you should be able to get an electric brake kit pretty easily.
