2001 Jeep Cherokee Part Ouy
K5Matt
Picked up this Jeep today.
4.0, auto, 231, d30, 8.25. Has 258k miles
It is in rough shape. The body panels all have damage or rust. The right side doors might be usable.
Interior shows its age and wear. It is dirty but all there.
Hood release is jammed or something, haven't been able to see if it runs.
I'd like to keep the wheels and tires, but everything else is avaliable.
Let me know what you need.
Sent from my SM-G928V using Tapatalk
Jeepguy91
Active member
Board of Directors
Don't really need it but curious as to how much for the 231 t-case? Have been thinking of swapping my 242 out this summer.
XJ-ARNIE
Don't hold them for me, but if I line everything up and end up needing them I'll let you know. Thanks
JohnX
Sarge <3 Ben
Headlight wiring harness and lower air filter box?
Shipped to 91701 CA
Thanks.
BIGSLVRXJ
Hey Matt, you might hit up the other Matt (OKB) to see if he still needs an engine harness for his '01.
K5Matt
Haven't been able to get this Jeep running, so I can't vouch if the harness is good or not. There is some total HACK wiring on the passenger side fuse panel too. Does he need a complete harness or can I clip something off for him?
BIGSLVRXJ
He was wanting the whole thing but he might take just the fuel injector portion too. Not sure if he got it fixed after WF.
oldmemories
just curious how much for the front left caliper and rear ebrake lines from the drums to the connection split (i don't know what you call it)? 60031
thanks
John D
NAXJA Member # 788
I'm looking for the snap in center console shifter bezels, both transmission and t-case. How much to put them in a USPS flat rate priority mail box and send?
Thanks, John
K5Matt
Quick run down of what is gone:
Rear license plate trim bracket/bezel
Rear axle
Wheels and tires
Cam sensor
Alternator
Coil Rail
Transfer case/auto trans gear selector bezels
Front Axle
Front Seats
Drivetrain is out too, going to pull a few more parts, then off to be made into Harbor Freight tools whenever the new title shows up.
