7/8 heim steering bolt length?
SeansXJ
Anyone mind sharing the lengths on the bolts. Im away from my rig and I plan on hitting the hardware store on my way home.... im going to be running RuffStuffs kit on my 30 with stock knuckles drilled out.
Thanks!
Sean
sunburned
So you're getting 3/4" bolts right? You should have 7/8 x 3/4" heims for the tie rod (knuckle holes drilled to 3/4") and 7/8" x 7/8" heims for the drag link with misalignment spacers reducing the bolt size to 3/4".
I bought 3/4" (16tpi) x 3.5" long bolts and 4.5" bolts. Pretty sure I used the 3.5" bolts at the knuckle where there were no spacers and the 4.5" bolt at the pitman arm where there were high misalignment spacers (plus I made the pitman arm double shear. My drag link was connected to the tie rod using tabs, so I didn't need a super long bolt at the passenger side knuckle. I used distorted thread flanged locknuts to hold everything in place. No problems at all.
