A question for you spring under guys
Swamprat
How much lift are yall running? And how? I'm trying to do something different here and remain springs under, but still net maybe 5" or so of lift. i've thought about re-arching some 64" leafs. My problem with that is all the leafs I can find are for heavier trucks. Also thought about going through deaver or a custom spring company like that. I have also thought about flipping my shackles. Just thinking out loud.
Johnnie Walker
Piece of Fish!
Deaver, National, Alcan etc will make you what you want. Not sure on their tallest lifts, but Hellcreek springs is a vendor over at Comancheclub. One of the few other companies I know that makes MJ specific leafs.
I too want to stay sprung under. My MJ is currently a rolling chassis but has some kind of bastard pack on it.
desertmike345
I have an RC 4.5 long arm on mine. I've been looking for some leafs to level it out. There's not to much out there. I thought the Hell Creeks were going to be a little tall. I finally ended up with Rustys 4" leafs. Just put them on about 100 miles ago, not a DD. They ride nice. I'll see how they hold up.
88whitemanche
I got the rough country add a leaf in the back of mine....I dont haul much stuff and my springs weren't sagged neither...you could just either buy hell creek springs that they offer a 4.5" lift and put chevy drop shackles and add additional 1"....
cheapcherokee93
<----boat-manche
im still spring under on about 4" of lift. I had deaver build me a badass custom pack to accommodate extra weight since my rig is used for overlanding. Before that i made a bastard pack for 3" lift using F150 leaves
IdahoEagle
56" Chevy springs and fullsize Jeep rears like from a 76-up Wagoneer, Cherokee (76-83), and J-10 are a great solution. And why stick with spewing under if you are planning that much lift? I can see it with 2-3" and wanting to keep it simple and low...
Swamprat
Thinking out side of the box, i'll probably end up going spring over with some long spring perches
blondejoncherokee
I am going to try to keep my new MJ at around 3.5-4" spring under. I have some 3" XJ AALs I am going to try, hopping they net 1-1.5" of lift, hoping for more but I doubt it . And then I have some longer shackles to throw on as well. I am very interested in the F150 bastard pack, any specific years that I should look out for at the junkyard?
cheapcherokee93
<----boat-manche
Its been so long I can't remember the year of the truck I got it from. Maybe 97? When I got them I literally was looking for anything with 2.5" wide leaves that looked like they have a bunch of arch.
blondejoncherokee
I might give that a shot. I am also considering cutting the eyes off some XJ main leaves and adding that with the XJ 3" AAL to see if I can net between 2-3" of lift with leaves and another 1" or so with a shackle.
87manche
the XJ springs are arched less, they will not get you anything near the advertised lift.
skyjacker used to make 3" AALs for the MJ. They were dumb stiff and will lead to bent main leaves if you wheel hard or load the bed to capacity.
FSJ waggy springs are very similar in length, No idea on static arch. Might be another option if you're looking to build a bastard pack or find an AAL. I've not dealt with them.
DaKing
What benefits are there for spring under, on the Comanche?
Does it limit wheel hop?
Better Flex (actual or potential)?
Better Droop ?
Just asken. I did a spring over, with longer shackles. I used longer spring mounts to help with wheel hop. But, I'm thinking the longer pads may limit spring compression, when under hard flex.
87manche
it does limit hop as it won't wrap the front of the springs as much. Takes away the leverage of the axle hanging down underneath and trying to rotate up.
no other real benefits that I know of.
shortxjdoug
Just for the sake of discussion ill share my thoughts. my next comanche will remain spring under on stock leaves because i'm going short lift and will be able to accomplish it all with mount and shackle lengthening. The main reason is to keep the axlewrap to a minimum. I'm not interested in spending a bunch of time and money on a well tuned leaf spring and traction bar system just to rip it all out next winter for a 4 link. Simple, effective, durable and all the parts are already here. its always been a popular option for prerunners and desert racers since it is easier on the springs and can still be engineered for excellent travel and stability
blondejoncherokee
I am getting some XJ 4.5" packs without the mains.
I am Going to add the second tot the to leaf along with my 3" XJ AAL to see what that does. If it settles below 3" then I will add a 1.25" shackle lift.
blondejoncherokee
Threw a 3" XJ AAL on the driver side to start and it netted around 2.25-2.5" but it hasn't been broken in yet so I am sure it will settle. I will probably just go SOA later on.
87manche
be wary of bending the main MJ leaf if the AAL does not go past the shackle eye.
Happens to everyone that runs an AAL on the trail. The MJ leaves are that soft.
blondejoncherokee
crap really? OK this is good to know. It goes very close to the eye, its longer than the second to the top leaf so it is the second longest leaf now.
I will probably end up going SOA and removing the AAL, maybe go with 2wd leaves since this has the metric tone package.
