Holy crap. No way! Even SUA ? I would think this would be better than before spreading the load on the main even further...mine were similar.
bent the spring eyes down.
Do you by chance have the specs for replacement bushings for these? I may consider running these if I cannot build a pack to suit my needs. Can't afford Deaver, although that would be amazing.I am running Rustys 4/4.5" MJ SUA leaf springs in mine, and will run them (probably the same ones) in my next MJ build. Quite pleased aside from quality of the rubber bushings included, and the fact that they use oddball dimension bushings instead of standard XJ/MJ sizes, which led to some annoyance when putting replacements in.
These ones: http://www.rustysoffroad.com/rustys-leaf-springs-mj-4-rear-pair.html
Well Jon, if you go SOA. Can I have your stock leaf spring plates? I need some with the shock mount for my MJ.the 4" rustys leaves were very tempting.
At this point, I would rather have the clearance from a SOA and not have the boat anchors hanging down below the tubes.
Already have the perches and shock mounts from Barnes , and grabbed some 2wd leaves locally as well.
