Magus2727
I have been battling my AC not working for the longest time and we are having record highs out here hitting at and over 100 F. I think I may have narrowed the problem down to possibly an electrical problem.
When driving at freeway speeds (dont worry I was not the one taking the picture) My volt meter can drop as seen here and even lower to just at the white line:
But even when I turn everything off its in the middle between the low side and 14V. I know dash gauges can be less accurate, but a dash voltage gauge like this should be fairly accurate. I have measured the voltage at the battery with everything running MAX AC max blower and measured 13.7V on the battery. Turned it all off (the AC and Blower) and still measured 13.7V at the battery. I know you usually see more of a 14.5-14.7V with the vehicle running shouldn't I? It starts great every time regardless of how long and low the voltage needle on the gauge is. How good are the tests they do at auto zone that attempt to load down you alternator and test it while on the vehicle?
The voltage gauge also does not matter if I am accelerating, idling, braking, or maintaining a constant speed. (my freeway speed due to my tire size is just at 2,000 RPM)
Could my alternator have some damage to it or just be old enough (have 196k miles on the jeep and think its the OEM one still).
Or I was thinking since I am seeing alright voltage (above 12v) on the battery the voltage drop I am seeing has to do with something in the cluster panel? How much should the needle change when you turn the blower on (either with AC or just Vent)? The gauge would lead me to believe that it might be seeing as much as 1-2 volt drop from off to full. So could my Blower be going bad? It does make a sequel when its cold out for a few min until I am guessing the bearings warm up.
Also when you select max AC the blow should push out more air with out changing the blower speed? While diagnosing this today I observed that the air output actually drops when I switch from AC to MAX AC.
Last thought would be due to the combination above possible items does an AC clutch need a higher voltage to always properly engage? If I am observing a lower voltage (even though the battery has 13.7V on it) after the relays and fuses etc. for the AC clutch could my gap be slightly large enough that the voltage threshold is not lower so with my other possible voltage doping problems I might just be seeing a to large of a gap on the AC Clutch?
When I have the blower on the lowest setting and the AC on I usually dont run into any problems with the AC clutch not engaging, its only when I up the fan speed to try and cool down more. And With 100F outside even with the windows down after running to the store the AC on the min blower speed is not even noticeable.
Any help and or thoughts would be much appreciated!
