Aussie locker 8.25 replacement
SeansXJ
I have a aussie locker in the 8.25. I am replacing the spring and pin kit but i cant seem to figure out how to get the c-clips off of the axles. It seems to me that there is a spacer or cover over the clips inside of the aussie locker. I cant figure pout how to pull the axles after the aussie locker is installed. any advice would help. thanks
XJensen
Spray some brake cleaner in there, turn the window/slot upside down and push in and shake the shaft. It should fall right out with a little luck.
SeansXJ
the spacers are in the way though. The clips are behind the spacers. Are you saying the spacers will fall out? If i get those out i can get to the clips
SeansXJ
you are correct but that is in the install. That post doesnt show or say anything about the install of the c-clips after the locker is in and it doesnt show how to pull the aussie locker back out. I saw that post earlier. It seems getting the locker in is alot easier than getting it out. If i could figure out how to get the c-clips out after the install i would be golden.
XJensen
All the lunch box lockers I have seen that have c-clips have slots for the clips to fall out. you can see them on the aussie in the pic of it apart on the ground. The gear oil will cause suction and make them hard to fall out.
If there is something in the way I don't know what is could be.
have you tried to hold one wheel and rotate the other to get it to ratchet and maybe get things lined up.
SeansXJ
hey Josh that was my buddy David using my SN ...he said he got the clips out by shaking the aussie a bit, he ended up stripping the splines on the Aussie and the shaft he found out...time for a new locker and pass side shaft..he told me to thank you for the help.
XJensen
Was it a 27 or 29 spline? I have some 27 spline shafts here, they'er Jon's but I am sure he would be cool getting rid of them, or the whole housing for that matter.
blondejoncherokee
dude those are NAXJAs shafts. haha. that axle went from billy to terrance to me to josh. its just getting passed around to who ever needs it.
Letterman
Maybe a dumb question, but did you pull the center pin? So the axles can slide in and let the C's fall out?
