Aux fuse box
XJensen
I am looking into adding an aux fuse and relay box to properly run some electrical. I am looking at the following but was not sure if I need the relay side bus too, dual bus, or just the fuse side.
I assume just the fuse side sense what I understand I should go from batter to bus to fuse to relay anyway.
Just looking for some conformation or correction before I buy a single bus, fuse side only, box.
https://www.waytekwire.com/item/46345/EATON-s-Bussmann-Series-15303-5-2-4-RTMR-Mini-Fuse/
#S194
Sierra Chapter President
Josh, check out Blue Sea Systems. they have some really nice stuff that is marine grade. I checked out some threads on Expedition Portal, gave me some great ideas.
XJensen
Did you use one with the bus only on the fuse side or also on the relay side? Ie two inputs from the battery or one?
kcjeep6
I run the same AUX Fuse panel with two buss bar, one switched and one non-switched. the only complaint I have is the mini fuses can,t 30 amps even though 30a fuses are available, They don't have enough mass to handle the current and will fail in a very shot time.
#S194
I used the safety hub 150. It has six ATO fuse slots and four AMI fuses for higher amperage stuff.
PhotoJared
I have this in one of my Jeeps. I dont have any switches hooked up to it as its just used to power some ECU triggered items. Add some switches and you're golden.
https://www.ebay.com/itm/Universal-Relay-fuse-auxiliary-distribution-box-jeep-Cooper-Bussmann-Spod/323169083009?hash=item4b3e60de81:g:2vQAAOSwe-FU6d9q
I also purchased one of these for my other Jeep. I built a switch panel to replace the JK one. I really like the easy integration.
https://www.amazon.com/gp/product/B06XCN5TKM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
