Back and forth play in TC Yoke okay?
mbogosia
I am chasing a vibration in my front driveshaft. After removing the driveshaft I noticed the TC yoke can be move back and forth about an 1/8 of an inch or so. Is this okay? Should I tighten it down until it stops? Could this be my problem?
Boostwerks.com
NAXJA Supporting Vendor
I'm willing to bet it's the whole shaft moving, not just the yoke. I think mine does the same thing. Not sure if it's a major issue or not, but I also have a vibe/noise coming from the TC.
mbogosia
It kinda moves in and out jsut a bit. Not sure if this will solve my vibration issue though. I'll tell you it is getting old trying to figure this out.
dave92cherokee
It sounds like this is what he's talking about. He's not talking about the drive shaft moving he's talking about the front output shaft moving which they will have a very slight amount of play.
mbogosia
Well after removing the shaft and just driving around for a while I can still feel the same vibration but it is much less. So, it must be coming from the rear drive shaft and then resonating up front when the front shaft is in. Man, I might just take the BB off and drive this thing stock.
