belly pan skid plate
AJTorris
Ok so i have used the search a bit this morning found a few pics of them but nothing really what im looking for.
I recently lowered my jeep a bit so now i am wanting to do a belly skid and other armor. I never needed it before but now since im a bit lower i want to protect everything.
Im wanting to build a skid that will protect my trans pan and tcase. I plan on tieing into the xmemeber for this.
I was thinking of doing a brace behind the tcase that will tie into both sides of the jeep and run a support beam to the xmember and plate it. Same with the front.
Maybe someone on here can point me in the right direction for this or find some examples of what people have done before.
VAhasnoWAVES
take a look at the kits clayton and TNT make. might give you some ideas.
beyond that, google is your best bet. i know a few people here have done full belly skids as well.
rockclimber
Associate
my transmission crossmember is a piece of C-channel notched for the driveshaft and exhaust.
the skid was built like this. not quite flat, 18" at the lowest point with 4" of lift on 33"s
cut outs for the transfer case and Cat.
full wrap on the unibody with anti-crush sleeves and nuts welded onto the crossmember to tie it in
bolted on
I've been acquiring parts for the exhaust swap to tuck it up higher. Cat, Muffler, etc etc... once I get that done I can do a transmission skid.
AJTorris
ya i have a single chamber flowmaster. I plan on redoing my exhaust anyways from the manifold to the bumper. Right now it turns down at my axle
rockclimber
Associate
It is? Where at on the exhaust? My cross member is flat with the frame rails. My exhaust is pushed up really close to the floor, but I don't think it is touching.
My exhaust touches the floor.
But the way it is bent, if you want to cover the transmission oil pan, you need to re work.
89limited_hero
i liked the hooligan offroad belly skid, but don't think it covers the transmission pan any.
but there is also oil pan and trans pan skid you can get to make up for that.
