Bent tie rod ends
XJensen
So am running a 44 front with Ruffstuff hi steer arms and a true cross over steering. I have a TNT truss and room is tight between the axle side pan hard bracket and the tie rod. I would rather not cut up the bracket but want some more turning radius back.
I bought some offset TREs but space is to tight between the drag link and tie rod ends. I thought about switching the offset TREs around on the tie rod and bend the tie rod but then would need to pop and end off to adjust the drag link or tie rod, not a hug deal but would like a better solution. Looking at some HD trucks they use bent TREs to keep bar straight, as well as some cars.
Any have experience or knowledge of a TRE that has the same taper and size as the GM 1 ton stuff? I am looking for something like this, or this may be it, I have not had much time to research yet.
http://m.summitracing.com/parts/mog-es443l
1990JEEPXJ
Maybe I'm dense but what do you mean by there is not enough space between the tie rod and drag link to run off set ends?
Pics?
XJensen
Pics?
Hopefully this will help. Running the offset ends in the standard direction will cause the extra "meat" on the body of the tie rod end to hit the drag link.
1990JEEPXJ
Got it. That makes sense. I'm guessing you can't switch the position of each on the high steer arm as you will need a shorter pitman arm as well
XJensen
Correct. My only options I can think of are bent TREs, bent drag link and tie rod or full hydro. The latter is out of the question so...
I am hoping to find a prevent TRE like the one in the first link that has the same size and taper of the GM 1 ton.
Johnnie Walker
Piece of Fish!
Since you are running high steer anyways, is there a reason you can't run the tie rod under the arm? Then TRE clearance is a non-issue.
XJensen
I could run the tie rod under the drag link end but then I would need to run heims and would lose a little clearance. Not that big of a deal but I prefer TRE over heims. Not interested in debating rod ends though
XJensen
Best thing I found was for a late 70s Chevy Camaro but the stub diameter was to small, shaft was 11/16 instead of 7/8 too.
Looks like I'll put some bends in the drag link and tie rod and pop them off the arm to adjust the alignment. At least i don't need to do that very often
