Ok so my jeep was rear ended at somepoint in its life and then was rear ended again by a buddy on a snow run (he replaced my light he broke lol). Well looking at it again im thinking i should fix and strengthen the frame rail a bit since it is a lot weaker now than stock.
It is bent a bit at the back of the hitch mount (towards the front of the jeep). It makes my bumper lean downward a bit as well.
Im thinking of cutting out the section that is bent, run 2x3 tubing into the frame rails as far forward as i can and then plating it off for the bumper mounts. Now by doing this i would need new shackle mounts. I really need a relocation box anyways so i can have a better shackle angle. I have seen people redo their shackle mounts a lot on here but im wondering the best route to go on this project.
Any advice on how i should do this?
I figured i would drill some holes in the existing frame rails to spot weld in the 2x3 tubing, weld it in sections along the floor board of the jeep, and then tie it into the other side of the jeep with a cross member. As for the shackle mount i figured i could do a piece of channel and drill through it where i want the shackle at.
