Yah, that's the one. The plug is really too snug for such a small head, especially after many years, and the previous owner had apparently tried to use an SAE wrench on it. By the time I got it, no Allen wrench would fit it tightly enough. The big old 30mm is much nicer.Mine uses a 10mm (I think?) Allen...
I found a lot of the sockets have a bevel on the inside to help guide the socket on to a nut. The problem is that the plug isn't very tall and I had a problem of the socket slipping off due to the bevel. I ended up grinding the socket down so there was no bevel and it worked a ton better.Thanks for all the input gentlemen. I've got the one that has a giant 30mm head and ofcourse I don't have anything over 18-20. Gonna swing by NAPA or Advanced at the end of shift today.
I've done this too, not for this exact application but for a similar low profile nut (I think something to do with a JGC PS pump?) I used a HF impact socket as it's cheap and 6 point.I found a lot of the sockets have a bevel on the inside to help guide the socket on to a nut. The problem is that the plug isn't very tall and I had a problem of the socket slipping off due to the bevel. I ended up grinding the socket down so there was no bevel and it worked a ton better.
Just an FYI...Thanks for all the input gentlemen. I've got the one that has a giant 30mm head and ofcourse I don't have anything over 18-20. Gonna swing by NAPA or Advanced at the end of shift today.
Alas, the TC is not pipe threaded.Is it still 1/2" NPT like the front axle? I was going to order some magnetic plugs while I had it on the lift the other day but the NAPA guy acted like I was asking for a third ear or something, so I will have to mail order. Also are there any inexpensive turdy-five covers with a pipe thread fill plug?
Pretty sure mine is, but mine has the hex recess not the 30mm hex. Apparently two completely different back covers then?Alas, the TC is not pipe threaded.
I don't recall that the hex was tapered like pipe thread. I do know that the 30 mm. plug off an 89 TC I had in the barn worked in it, so as far as I can see, they stayed the same.Pretty sure mine is, but mine has the hex recess not the 30mm hex. Apparently two completely different back covers then?
