bones needs help
bones5150
ok guys i tore apart the front of sally to install some coil spacers. and everything that could go wrong.....went wrong! one of my upper control arm bushings majically worked its way out, i dont have a ball joint press to put the new ones back in with, and i cannot afford to rent one from autozone. also even before that happened i could not get my LCA bolts to line back up. im definately a newb when it comes to this front suspension and i need help. can any of yu guys come lend a hand? this is my daily and its sitting on jackstnds and i can only use the misses truck for a few more days.
Hypoid
Question #1: What kind of control arms? Sorry I don't remember if they were stock or aftermarket.
On the LCA bolts, I put a big pipe wrench on the axle tube, and a floor jack under the wrench to rotate the axle and line the holes up.
I'm not sure when I can get over there again.
bones5150
ok, hypoid gave ome good advice. just one thing lef to figure out. i bought new upper control arm bushing and im guna press em in redneck style. but what about gettin the old ones out? i dont own a socket close enough to the size to hammr it out, and i dont have air or an air hammer. any other suggestions?
Stang5lgt
You can drill the bushing out with a drill and then beat the sleeve and crush it down and it will fall out.
Hypoid
I called Bones before I had to leave, he has Rusty's control arms. If there's a trick to those bushings, now would be a good time to reply.
YELLAHEEP
Last I knew, Rusty's uses stock rubber bushings. No real trick, pretty much like what was said already, use a drill and perforate the rubber until you can rip the rubber out, then use a hammer/punch or chisel and start tearing into the sleeve. I've used a sawzall to cut the sleeve with decent success - the cut will relieve the diameter of the sleeve and allow it to compress and become loose.
goodburbon
Throw the CA into the bbq pit and burn out the bushing.
Use a torch and burn out the bushing, then cut the sleeve
Drill out the bushing and use a sawzall to cut a notch into the sleeve.
get a sledge hammer and cut a hole in a 2x4 the size of the bushing. Strap the arm to teh 2x4 with the bushing over the hole and hammer away.
Air chisel is still my favorite.
I wish I could come help, but I think Aurora is a litte far from Westcliffe.
eflores
man just bring it to the springs and we can press it out and in with my press while we are unloading it all :D
bones5150
alright well i got it. and BTW it was the upper control arm, where it presses into the top of the diff. i hammered out the rubber and then taco'd the sleeve with a flathead and a BFH. took 2 hours but it came out. then i built a ball joint press out of some scrap metal, but i dont hve any hardened bolts, and the one i tryed to use stripped out, will have to wait till tomorrow
XCastleXJ
im curious why you unbolted the control arms? i didnt feel the need to do that when i installed some 2" spacers on my XJ.
Hypoid
He has lift coils, at least three inches.
I borrowed spring compressors to put spacers on my ZJ coils, only loosened the CA bolts. I could see where more spring would be more involved.
