I'm looking to swap a 1998 XJ Booster into my 89 MJ. The rod on the 98 is about 3/4" longer. I'm done some searching and found http://www.madxj.com/MADXJ/technical/technicalfiles/ARbrakeBoosterUpgrade/BrakeBoosterUpgrade.htm but it doesn't say how the rod swap is done. Do you need to pull the booster apart to do this? I'm thinking it might be easier to weld a tab onto the front edge of the brake pedal arm with a hole in the right spot. Any one done either option?
