For sale. I'm putting a Dana 44 on the front end and changing bolt pattern. Parts will be available late April/early May. Located in Everett, WA. May be able to deliver within a reasonable distance. Make me an offer.
a) HP Dana 30: 4.56 Yukon gears, Yukon chromo shafts, ARB locker, LCA mini skids, RuffStuff diff cover with Lube Locker gasket, new Black Magic brake pads and Centric rotors, Ubolt pinion yoke. Drivers side knuckle has GoFerIt insert to run the Currie steering OTK. $750
b) Currie steering: new tie rod ends at the driver knuckle and pitman arm. $275.
c) 33x12.5R15 Goodyear MTR-K tires mounted on Aluminum wheels (American Racing AR-172 Baja wheels, I think). 4 tires included, no patches. Bolt pattern 5x4.5". 50% or better tread, will measure. $500.
d) 33x12.5R15 Dunlop Mud Rover spare tire on black Soft 8 wheel. Has never been run, still has the nubs on the tire. $150.
e) ROLA Roof rack: this one: https://www.etrailer.com/Roof-Basket/Rola/59504.html
Includes the extension - it covers most of the roof (I think total length is 72" but will measure). Includes crossbars that mount to the drip channel. $175.
