88 Wagonman
When I pull out of my driveway and hit the brakes, it makes a single clunk, and when I go forward and hit the brakes it also has the same clunk, but only once. I will not make the clunk again until I go in the other direction. It sounds like its coming from the passenger side wheel, but you can feel it very faintly in the cab. My first thoughts were that maybe a u-joint was bad, or a loose caliper, but they are fine. Any ideas on what to look for?
On a side note, does anyone else feel like a retard just for posting in the oem tech because you couldn't find an answer on your own or from searching?
