D30 Axle Shaft Interchange
bigalpha
Oh the huge manatee
Maybe my google-fu is poor, but I can't find a comprehensive list of axle shaft swaps. I've seen that some TJ's will have shafts with 297 joints that will swap, along with some Grand Cherokees.
I currently have a 1992 XJ, non-ABS, non-disconnect. My understanding is that this D30 has the 260 u-joints. Swapping out the axle shafts could get me the 297 joints, which are stronger.
So the extent of what I think is accurate is below. Can someone expand this list?
XJ
1991-1995 with ABS have 297 joints.
1996-1999.5 all shafts have 297 joints
1999.5+ require hub swaps
Digger87xj
XJ
correct, but no hub swap required for any years.
ZJs will swap. most have CV joints though.
all TJ's had 297 joints and all D30 shafts are interchangeable.
ehall
My 1991 stock XJ shafts had the 260 joints (small), I bought a set of TJ shafts with the 297 joints (large) which I have been running ever since. I'm not 100% sure about ZJ/WJ with the alum housings but AFAIK they are the same too.
bigalpha
Oh the huge manatee
Thanks. Going to hit up a few junkyards so wanted to expand my horizons as much as possible.
