Dana 300 with tera low 4:1
FuzzyD
selling my dana 300 with tera low 4:1 kit. the kit is still brand new with new bearings. it is partialy installed to make sure everything lines up correctly. asking $900 never been on the road 0 miles on it, it still need the other shifter lever. i have one but need both to isolate front and rear if you want to do front/rear digs. it has 23 spline input so it wont work older cherokee's but i do have a spare late model aw4 that you can have. but it dose need a rebuild or you can swap output shafts witch is waht i was gona do. pm with contack info and i will get back to you asap. located at my shop in glendale.
