Magus2727
I have my Jeep that over the last few weeks i have been experiencing additional drive line vibrations when the throttle is pressed in. the vibrations are the same regardless of the amount the throttle is opened or what gear or even speed. The second I let off the throttle the vibrations go away and have just the normal vibrations from my big tires.
I thought I might be from the front drive shaft the front axle had no play but the connection to the transfer case appeared sloppy (guess it should be since in 2-wheel drive the front axle is not "connected"). but after pulling the front drive shaft the vibrations are still present.
Any idea on what might cause this vibration when under load and not when coasting? and when I mean load it could be 5% throttle when on a decline or 100% throttle and down shifting into 3rd or even 2nd.
Thanks for any help any one can provide.
