Drive line vibrations
ZJTROY
Had a growling noise on acceleration found i had a collapsed passenger side motor mount (see pic) replaced it now there is a bad drive line vibration at 60 to 70 MPH. Drive line angle is correct took out drive shaft and run with it off you can still feel it. Almost like transfer case or trans issue. Has anyone seen this before I start digging into it with both shovels?
smokeyyank
Jeepoholic
You could have a bad tranny/tcase mount. If your motor mount was shot it's going to place that stress somewhere else along the driveline. If you eliminated bad ujoints/driveshafts by pulling them the mounts would be the area I'd look next.
P.S. pic never showed up
trippled
Specs on this? Assuming this is 4wd, which shaft did you pull? Did you check the other? How does it feel like driveline vibe? Any chance it's tire balance?
PacificEd
YOLO!
Is it rotational? I have a vibe that only occurs between 45 to 50 mph. I've been thinking it's a front drive shaft.
If you removed the front driveshaft and it's still there, I'd look at the other engine mounts, front axle joints, and the rear driveshaft u-joints.
ZJTROY
Have not been on here in a while, after lots of parts and cash I finally got a great deal on a rebuilt trans. And low and behold all vibrations went away. Go figure.:party:
PacificEd
YOLO!
Was the overdrive lock-up in the torque converter bad? I did have to get our trans rebuilt for that reason. The ZJ would sound like it was buzzing and vibrating really bad starting at 45 mph.
