feeler 44/30
AJTorris
Ok so i am possibly going to be throwing in full size axles here soon so figured id start a feeler for my axles.
They were rebuilt about 10k miles ago. They are a 44/30 set up with 4.56 gears and aussie lockers in both. the dana 30 has a jeepspeed style truss on the bottom side as well. the 44 has had the factory shock mounts cut off because i moved my shocks to the top of the leaf spring plate. the 30 has had the factory shock mounts cut off and the shock mounts were moved down a little with shock tabs. the 30 was a disco housing and has a solid shaft in it with the correct seal. all shafts are stock. I also have 2 or 3 sets of spare shafts ill throw in with the 30 and a spare set for the 44 as well.
Figured id start it off at 2000 and see where it goes.
AJTorris
Also the dana 30 axle shafts that i have are
1 set is stock out of a 93 i belive
1 set is stock out of a 97
the other set isnt chromo or anything but the ujoint knuckles are splined on the inside where the shaft goes to them. So they seem like they may be aftermarket but i can not figure out the brand of them.
