So Ive got my 3 link (front) designed with proper geometry but have not been able to find the answer to my dilema. the single UCA will be 18-20" long(depending the AD% I like best) and the lower CAs will be 26" long. I would prefer to have the lowers longer @ 29-31" to make mounting much better and a little higher but if the lower must be closer to the upper length the 26" arms will work just not with my prefered bracketry design.
Would there be a problem with running a 20" UCA with 30" lowers in the front suspension? I searched and searched but found nothing on prefered link length FOR THE FRONT. I know the rear suspension works best with apx 25% shorter uppers is this true for the front even with the forces applied backwards?
Thanks in advance, this project might actually get started!
