'07 Commander 4WD.
I found a 1" puddle of stinky fluid after I put the Jeep away tonight.
After getting out the flashlight and crawling around I saw fluid marks on the Pass side tire and the inner fender, but no fluid on the axle shaft or brakes/brake lines. What I did see was fluid accumulation on the pass side inner fender behind the shock, and on the lower frame. I saw there is a hole in the inner fender and no fluid above it, so I looked on the engine side and found, what I believe is the source - the diff breather. The viscosity and smell matches what I found on the ground.
I saw on a Dodge truck forum that there is a TSB due to leaking at breathers on those vehicles caused by drivers starting off cold and getting up to speed without a warm up. We had a couple of cold snaps, and yes, I usually just start, wait 30sec to a min and go.
I've had the vehicle since April and haven't noticed this before.
Thoughts?
Thoughts?
