front end
azxj95
so i just finished up my lift took it down the street everything was fine untill i hit a good size bump then the streering wheel and front end started shakeing really bad couldnt stop it untill i almost came to a complete stop i start going again and its fine untill i hit a big bump and it starts again.
What could this be
jbsjunk
The dreaded death wobble. Has it been aligned yet? That and a good shakedown on the front to check for loose parts would be a start.
azxj95
nope no alignment yet and i pretty sure everything is tight ill double check thought i have a full size 44 and 1 ton steering up front is that going to matter when i go have it aligned
tonysinnette
It depends. If its a crossover steering set up (drag link connects to both knuckles and tie rod connects to the passenger knuckle) then you shouldn't need one. I got death wobble really bad with my first lift just because the angle of the track bar was bad. There is a lot of stuff that can cause it. You could make sure your ball joint and wheel bearings are tight too.
whitexj98
Inspect your track bar, have someone move the wheel back and forth while you look at the track bar ends for play.
azxj95
everything is brand new so there shouldnt be any play and i dont have cross over steering my drag link connects to the bar that attaches both knuckels together ia cross over sterring better then the set u i have
tonysinnette
That shouldn't mess up the alignment then. Was the alignment good on the axle before the lift? I would do like whitexj said. Get someone in the jeep and have them turn the steering wheel to see if anything binds or moves in a way it shouldn't. Check your front DS ujoint too. Ive had one go bad and vibe real bad. Good luck!
tonysinnette
An alignment can never hurt, especially with a 3 link. Your going to get a lot less binding than before so you will get more movement both on and off road.
azxj95
call me dumb but iv never had a alignment done what do they do is it maybe somthing i could do
