Hardware for Attaching to Factory H.O. Era Roof Bars
Anak
Stranger
I stumbled across some square U-bolts that worked especially well for this application and thought I should share the information for anyone else who may be looking to do something similar.
Tacoma Screw Products has P/N 158-101-1, described as "3/8" x 1-1/2" x 2" Square Bend U-Bolts — Steel, Zinc"
Linky: http://www.tacomascrew.com/s.nl/it.A/id.5543/.f
These are a snug fit around the factory bars, almost so snug that I rejected them as a possibility until I test fit them in several different places on different bars. Whether the differences in the factory bars are the result of age/abuse or of loose factory tolerances I don't know, but I was able to get these onto the factory bars with a little finesse and persuasion (just by hand, no BFH required) in the tight places. In other places they went over the bars effortlessly.
The 1 1/2" dimension is the distance between the legs, and the 2" dimension is the length.
It was not until I was disassembling things that I remembered I wanted to take pictures, so these pictures show a state of nearly removed. The 2" length gave me enough thread to fit an SAE washer and Nylock nut over 3/4" plywood and have 1-2 threads above the nut.
Pics:
And:
Hopefully this will save someone else a hunt.
Greenspan
Nice, thanks for posting, I've been looking for a solution like that. I bought a set of U-shaped ones, but they don't work very well.
I resorted to drilling holes in the crossbars, but the bars aren't very strong to begin with so I don't like that option.
Anak
Stranger
I started with some U-shaped ones, but I could tell they weren't going to be what I needed, so I took the Jeep to the hardware store and they let me take pieces out to fit check them in the parking lot.
Greenspan
Sorry for bumping an old thread but my crossbars are a little wider closer to 2.25". It looks like there are 2 different styles of cross bars. I've looked all over the place and can't find square u bolts that wide that arent supwr long. Does anyone have any recommendations for the wider cross bars?
TRCM
use 2 bolts & 2 flat straps.....sandwich it all between the straps
Greenspan
Yeah that's the backup solution... Kinda sketch, it would be nice if there was a short square ubolt available. Or another clean option people used?
