Qban
I had some difficulty installing the JCR stage 2 rock sliders. I got the frame mounts bolted in without much trouble but I'm having some issues with the pinch weld side. most of the bolt holes will go completely through the pinch weld but a couple of them are offset and hang too low off the pinch (about half of the bolt hole is on and the other half is off the bottom).
How much of the pinch weld does there need to be under the bolt hole through them? (I hope that question makes sense)... and since I have one that's halfway off I was thinking that I should try to pull pinch weld lower but I don't know of a good way to do it, any suggestions?
Thanks a lot, I appreciate the help.
