OK
I HAVE A REAL FIX!
You just have to unplug a connector in the knee blocker panel.
Once you remove plastic panel, there is a metal one under that. Remove that as well. (They take 1/4 inch drives)
Now if you were to be sitting in the drivers seat, your knee would point directly towards this plug. It is black and is mounted parallel to the direction of the vehicle.
It has several wires, some green with white stripes, most importantly the red/white and the black, control the module (Thanks to Tomcat)
If you unplug the whole connector, it disables the whole "sentinel" lights and your HIDs go back to functioning like stock halogens.
I am not sure what the other wires going to connector do, how ever I went on a post-removal drive, and everything works so far...
The whole process takes no more than 10 minutes.
PM me if you need more help.
And Thanks again Tomcat for your help, couldn't have done it with out you.
Just put HID's in my 98' and it did the same thing. Another member gave me a tip on removing the number 3 and 4 fuse from the interior fuse block for the high beams and now they work fine. I didnt look into why it works this way but it just does. Maybe this will work for you
HID + stock electrical = ones tricky beast.:roll:Just put HID's in my 98' and it did the same thing. Another member gave me a tip on removing the number 3 and 4 fuse from the interior fuse block for the high beams and now they work fine. I didnt look into why it works this way but it just does. Maybe this will work for you
If you have the sentry module thing you will still need to unplug that. The fuses are for the right headlight socket.Hey guys im having the same problem to
If you wanna leave the fuses in you can just click the high beam on which is the normal light and they turn off
but i didnt know you could pull the fuses
is that in the block on the passenger side kick panel??
See post #2Sentry model???
I recommend you read through this thread:See post #2
Basically its the thing that keeps the headlights on for a couple minutes after you turn them off. My 97 didn't have one so all I had to do was the fuse trick I mentioned to get it to work.
Mine did the same thing, but when I shut the ignition of they would go off.Just installed a set of HID head lights and have a little issue. The lights come on fine but when I go to turn them off they dont turn off, I suspect this may be due to the valet switch. Need help locating it. This is a 97 XJ
Where did you get the harness?A $30-60 wiring harness will eliminate those issues and keep your wires safe.
If your igniting the ballasts with stock wires carry a fire extinguisher
I got mine on ebay, I think it was like $25 shipped.Where did you get the harness?
