Dude did/is getting a custom track bar made
Out of that whole deal.
Maybe I should try to make some axles out of pvc and see if any one will donate some custom axles. :/
lol Im going to glue some quarters to a tooth pick and run that!
those 16" airshocks stay "seated" throughout the entire length of travel. which is what we are trying to tell this guy to do, but he doesn't seem to understand that somebody somewhere may have already had his issue and solved it.The normal Wednesday night bash thread...
I had same issue didn't wanna loose flex , ended up cutting out the coil buckets an doing hoops an 16" travel airshocks , have weight on all tires , still needs limiting straps though
Yep problem is to make that flex work it cost me an extra grandthose 16" airshocks stay "seated" throughout the entire length of travel. which is what we are trying to tell this guy to do, but he doesn't seem to understand that somebody somewhere may have already had his issue and solved it.
welcome to jeeps.Yep problem is to make that flex work it cost me an extra grand
Welding coils?Um... You use limiting straps & tack weld the bottom of the coil to the axle.
It's not rocket science.
Brilliant :idea: !I made my coils from rebar.
3lbs of spring weight, 500lbs of static weightThat gives me an idea, we had tons of cutoffs of rebar coils left over from a continuous spiral caisson job a few years back.
How do I calc the spring rate? its #5 bar, and the coils are 2' in diameter. Would these work for my jeep?
no way limit straps will make his rig fold like a taco! and cause -10hp, and cause kittens to go blind!Did anyone suggest limit straps yet? I think I would try and use limit straps.
i hate cats anyways.no way limit straps will make his rig fold like a taco! and cause -10hp, and cause kittens to go blind!
so... you spent a grand on air shocks but couldnt justify getting rid of a D30 running 38s? :dunno:Yep problem is to make that flex work it cost me an extra grand
x2i hate cats anyways.
lastarai hate XXXXX anyways.
