HPD30 & D44 4.10 R&P
WAZZUXJ
I decided to jump to 4.56 gears so I am selling off the 4.10's.
Dana 30 RR
Dana 44 thick TJ Rubicon (uses 7/16" bolts)
$60 for either set
$50 for Red letters
WAZZUXJ
Since I also picked a Detroit for the rear, I have a stock open D44 series 4, 3.92 & up carrier. (no spider gears)
$50
$40 for red
WAZZUXJ
Still have gears and carrier.
Also, the Rubi D44 R&P will work in a non-Rubi D44. The gears only use a 7/16" bolt opposed to the standard 3/8". The gears are thick, so will work with a 3.73 and numerically lower carrier. You just have to drill out the R&P bolt holes.
Gears are clean and show little wear.
