Ignition wiring blues
XJensen
2001 xj
Jeep would turn on with the key but would not turn over, not even a click from the starter. Few days later it fired up and then on the second start the starter cut out after a second. I checked all the fuses and swapped relays no luck.
I turned the key on and jumper the starter. Cranked strong and started right up several times with this method. Oh I also replaced the battery too it was weak on the amps and better safe than sorry on the trail.
From what I gather this leaves me with the ignition switch and the neutral safety switch. Any way to test these?
I am also thinking of just switching the starter to a push button. I could hook it up directly but would think it would be better to use the starter relay and just bypass the ignition switch and the neutral safety switch. Thoughts? I was not sure how many amps the starter ignition wire pulls. The wire that initiates the starter not the one hooked to the battery.
Thanks for any advice.
Bobbie
Hi,Had a 99 Cherokee Classics do the same thing.The people i bought it from put a toga witch in it and it worked fine.Now i think the ignition switch is cheap price but a little work to install.
Please note That I stop for the broken down on the road,the homeless, and the ones that need help. I do this because The Man Saved me 2000 Years back.
Bobbie
Please note That I stop for the broken down on the road,the homeless, and the ones that need help. I do this because Jesus Saved me 2000 Years back.
Tim_MN
Freakish Hand Strength
The symptoms strongly suggest a faulty ignition switch. They are, easy to locate, low in cost, and simple to install.
If you jiggle the shifter handle in Park and/or in Neutral and the engine starts, the NSS needs adjusting or cleaning.
XJensen
Yeah i gave it a jiggle with no luck. Guess it need to figure if I spend the cash on an ignition switch or push start. I guess I will do the ignition switch sense it might be in danger of completely failing... I would assume at least
XJI6191
You mention a push start, so I guess you have a manual. I mention this because the the auto NSS is quite different (a) it's also the backup light switch so a bypass would be no more than a get-you-home fix (unless you can live without them - or manually switch them) but, (b) more importantly at this stage, in may experience, will require more than a little jiggling, but slamming back & forward through the whole quadrant maybe a dozen times - & even then you may need to repeat a couple of times.
XJensen
Good to know. I don't currently have reverse lights, installed LEDs and did independent turn signals.that would have been a good check.
I was going to switch in the push start at the starter lead. I assumed everything else would work just bypassed. At this point I think I'll send the extra. $20. I don't want it completely failing on the trail. I will try to move the shifter around more, it is an auto.
XJensen
Took your advise and moved it around pretty rough, just wiggled it before. It showed life and once I found the sweet spot it works every time. Just need to clean and adjust the NSS!
XJI6191
Good to know I could make some useful contribution - seems like I returned (after another year's absence) just in time!
