Many years ago, I recovered my headliner. The original foam backing was crumbling so I just wire brushed it off. Over time I've been ignoring the occasional wet spots from the condensation between the roof and the headliner. I've pulled the headliner again and I've got a bit of rust up there now, especially on the side near the pinch seam.
Once I've got it all dried out again, I'm planning to wire brush, but the hard part is the sides under the side channels where I need a mirror to even see the rust. I'll herculiner on all the flat surfaces I can get to to match the tub. Then either pull rags soaked with herculiner through the channels, or spray undercoating.
Any suggestions on foam or insulation to put on the back of the headliner?
