Same post on Pirate but in searching I found some of you are running this setup, any advice?
On my current XJ I have a radius arm front suspension consisting of a single upper CA on the drivers side. While this works well and the arms are tucked up flat inside the frame rails, I am wanting to try a differnt route for the next XJ. The Currie J-arms are what Ide like to work off of. I have the axle mounts figured out and the panhard bar is already raised to match the WJ knuckles.
I want to utilize a 3 link w/panhard bar. What would be the ideal AS% for the front and how does the roll axis and roll center affect the front suspension with a panhard bar? I would think a close to 100% AS but am unsure of the rest as the panhard bar changes everything right? I am looking for an improvement over my current radius arms both on the hiway and on the trail.
Here is what Ive come up with so far, 1st being J-arm lowers with stock located uppers as all the TJs I've seen do it. Doesnt seem ideal to me...
Here is with the same lowers but moved the UCA down and further from the axle.
Here is my current radius arms but I only run a single upper CA and it is attached mid arm, done right?
