So I bought a HP D30 to replace my disco D30 housing (couldn't get the inner axle seal to seal correctly) and I have a question about the knuckles. My old housing has the knuckles plus a separate caliper bracket and the newer housing I got from a newer XJ has the caliper mount built into the knuckle.
My question is this: Is there any inherent advantage to using either knuckle setup? I would prefer using my old knuckles since I could use known good calipers instead of taking my chances with the calipers that came with my new/used axle.
Thanks.
Thanks.
