Hey all.
Drove my xj out to a local river spot a few days back, about 40 miles from home. Lots of hills, 90 degree heat. Couldn't get out of its own way. Incredibly slow, hard to hold speed on hills, etc. Jeep has been well maintained for the 75k I've had it. Has 198k right now.
2001, 4.0, 4.56 gears, 33's and tons of armor.
Untitled by Sean Mitchell, on Flickr
Current engine mods- Otherwise stock internals.
-4 hole Grand Caravan Injectors
-Stock intake with front blocked off and rerouted to the cowl. (2.5 inch tubing- Shouldn't be that restrictive...Right?)
-DIY 60mm throttle body
-High flow cat and flowmaster 40 with custom pipe.
Cowl intake-
Did a compression check.
1- 85psi
2- 105psi
3- 95psi
4- 90psi
5- 95psi
6- 100psi
Retested 1 and 4, went from 85 to 95 and then 90 to 110 with oil in the cylinders.
So I was guessing rings. Doesn't burn much oil though. And no coolant loss. And I saw a TON of carbon in cylinder 1, which also had the lowest numbers. Is it common for carbon to stop valves from sealing well in the 4.0?
Thinking about doing a steam treatment. (slowly running water through intake.) Did the seafoam treatment a few weeks back too. Lots of smoke. My compression gauge was a rental from Oreillys so maybe I'll do the carbon treatment and then retest.
Advice?
Cowl intake-
1- 85psi
2- 105psi
3- 95psi
4- 90psi
5- 95psi
6- 100psi
Advice?
