davidson99XJ
ok so ive been driving my jeep for about a year now everyday as my dd no problems. about 2 months ago i started to get a loud pop in my front end when i turn the wheel without moving or moving slowly, i also had a very loud pop when i hit a pot hole or big bump. got to looking and see that my passenger lca was loose. that was the loud pop hitting bumps. i checked the track bar for the popping when turning and its tight. i cant find ANYTHING loose. About a week ago i went from 33/1250 to 33/1050 tires, seems like since i did ive got alot more play in the wheel. i expected a little more but not this much. on county roads or any bumpy roads where i can go 30+ every time i hit a bump or hill and the jeep floats to where the suspension droops down the steering pulls bad. the jeep itself keeps a straight pay but just the wheel turns. its like bumpsteer but it doesnt shake or wobble when i actually hit the bumps. its after the bumps or hills when the front axle drops down. if i have any pressure on the steering wheel at all the wheel will turn almost a 1/4 turn as the axle drops. i checked the angles of the track bar and drag link they both seem to be pretty close. i have the RE drop bracket so to even it out i put on a 1" dpa. im outta ideas. Steering box??? could that be the popping and giving me the play in the steering wheel? :helpme:
