need to buy a new carrier for my dana 30
BlueRockRash
I have 3.55s in my dana 30 i have the 4.88s i read i need a new carrier to hold the lower gears.... There is an option for loaded and unloaded what is the difference?
NotMatt
I believe it usually means it has spider gears, thrust washers and a cross pin installed if it's "loaded" and has none of that (bare carrier, literally just the chunk of steel everything is assembled around) if it's "unloaded"
xjtrailrider
should i get a loaded one or use my old spider gears an stuff im puttering a locker in it too aussie
If you are putting in the Aussie you will not need the spider/side gears, only the cross-pin. The cross-pin and cold roll pin that holds it in can be used from your old carrier.
NotMatt
If you're putting an aussie in, just order an unloaded one... but when you disassemble your old carrier, keep the cross pin, the roll pin and the side thrust washers on each side of the spider gears. I haven't installed an Aussie, but i have installed other lunchbox lockers that require you reuse the thrust washers... so keep them just in case.
