Obligatory "Fix it" thread.
XJumpmaster
I'll go first!
Finish hybrid cage.(DONE!!!)
Fab some tube fenders front and rear.(Fronts Done)
Prime and paint all tube work and rocker replacement.(Done)
Coat the interior.(Done
Re-install all of the plastic interior pieces.(Done)
Re-install seats.(Done)
Buy and install 4 point harness.(By Next Trip Turkey Fest)
Cut bottom off of doors to fit new rocker replacement.(Done)
Re-install tire carrier on rear bumper.(Done)
buy and install rear diff cover.(Maybe this winter)
buy and install shackle relocators(Maybe this winter)
buy and install new rear leaf springs.(Who knows when this will happen?)
cut holes for new shocks.(When I go to full widths)
buy and install new winch rope.(Who knows)
delete snorkel. (Done)
Fab and install cowl air intake.(Maybe this winter)
What ever all other minutae that it will take to "finish" this project!
Wow! What a list! Now that I see the list, I am feeling way overwhelmed and so over my head! LOL I will be busy for a while!
Updated 1 Oct. Its amazing how fast the money dries up! It puts everything on hold waiting for paychecks! LOL
Voteban
Entirely too many things..
Alternator
Button up cooling system
Fix drop brackets
Fab and weld on rear shock mounts
Fix a few interior pieces
Re-wire lights
Mount random XJ stuff I'll be getting on my bday in Sept.
Probably need to rebalance my tires..
Safety inspection..
I'm positive that there are more, just not any that I can think of laying in bed at noon. :D
stockerwithalocker
Got Shafted
I'll go first!
Finish hybrid cage.
Coat the interior.
Re-install seats.
Do you have any pics of what is looking like bud?
jmaxj
picture a 97+ with all the removable body panels leaning up against the garage and everything below the lower door hinge cutout. maybe i'll take some pics and send them to ya saturday.
my list(only if i feel like working on it)
link and stretch rear end
finish tube work on rear
cut off factory "frame" and build a better one
narrow and tube the front
install doubler and cutting brakes
do boatsides
finish keyless ignition
now what WILL actually be done.
broken axleshafts fixed
hydro assist re mounted
exhaust fixed
new alternator
new radiator
2 tires for trailer
even if its not all done my junk will be there cause i can't lose a bet to J-9 :D
DrMoab
Not 100% sure if I'll be attending this year or not. This list is the reason why.
New Cat
New injectors
New starter or NSS not sure which yet
New fuel pump
New steering
New shocks
New Alternator
front control arms need to be rebuilt
No money to do any of it...
stockerwithalocker
Got Shafted
I guess I will play since I got the old boy to pass smog with flying colors:
New roof/figure out how to get a windshield into mangled A pillars with huge gaps
Fit/mount new skins
New hood
Paint (Spencer is in charge of that)
Stop/fix the cracks in the steering box area
New steering linkage
Mount the Liquid Iron front plates (they look pretty bling)
Fix fuel pump issue
tear down/prep
If I get time buy & install seat heaters since I am getting to be an old man
Josh that hatch would be much appreciated. If it makes it easier for you, I only would need from the bottom of the rear widow down (thinking of making it into a "tailgate")
stewie
Finish body swap:
weld up DIY front winch bumper
clean up rocker replacements from old jeep, cut out rockers and replace
rework rear bumper tire carrier mounts
mount cb and antenna
mount trans temp gauge
mount alt gauge
wire in back up lights built into rear bumper
mount high zj alt
zj steering
wj ps pump
durrango box
oba
maybe install rear quarter guards
go on a deer hunt
all this in the Phoenix heat (still 113* today):flame:, thats why I have been putting it off
X1994J
I'm giving it hell!! Finshed bending tube last night! Needs welded, paint, seats & harnesses installed and i'll be there!
sanjuanxj
Just got new 5165 Bilsteins yesterday; the 5150's i've been running for the past two years started leaking just before the Little Sahara run in February.
-replace fire extinguisher
-change oil
-install new shocks
-clean K&N
-zirk everything!
MJR
Oil change, balance/rotate the tires, remove sagging headliner material, and clean the inside is the extent of my things done.
jmaxj
pull jeep off trailer, fix driveline, inner steering box brace and change alt and AC pulley. put back on trailer and head south.
