I'm prepping my 01 XJ for winter, removing rust from anywhere I find it & applying POR15 to end it for good.
My question is about the oil pan, it has a few bad rust spots, no where is oil leaking through but a few spots seem thin after removing the flaking rust, should I spread some JB weld over the spots in question, prep/paint with the POR 15 & be done with it or should I replace the pan?
Do all pans for the Jeep 4.0 Fit?
If I replace the pan should I use an aftermarket pan or OEM ?
EBAY Is full of pans, some have an "oil sensor hole", can I plug it?
Thanks for answers in advance.
