ParadiseXJ
OK, so I made a rookie mistake when I did my oil change yesterday...I'm not sure if I need to fix it or not, my MJ...4.0...AW4...190K
I bought the oil off of a display at the Zone. All (almost all) the jugs said 10/30. I also grabbed the sixth quart off the rack. Drained the oil, changed the filter, cleaned it all up, added the quart first, then opened the jug and started pouring...
...as I was pouring I noticed the JUG of oil was 5/30, not the 10/30 I thought I had. So the question is obvious. Is the 5/30 too thin or should I just run it. Ambient temps in the summer here run from a low of 40F to a high of 105F.
Should I change it, or leave it??
