parked it for a week now "no start" HELP
Strictly.Offroad
Hey guys looking for some advice. Went on my honeymoon last week and we parked my 88 4.0 in the garage for a week. Started when I left, not any more. The battery is good and is the starter. Yes I do have gas in the tank 1/2 tank. The motor turns over but not start up. ;( Any ideas are super helpful. Need it to start by Wednesday so I can get too work. Thanks guys.
89xj
cps, try disconnecting its wiring harness and reconnect.
also pull the coil wire off the coil and distributor cap and reconnect.
Shorty
Gone but not forgotten...
engine needs three things to start and run:
1. fuel-- verify it's getting it by trying a shot of starting fluid (ether) and see
if it starts.
2. air-- very slim chance it's not getting any
3. correctly timed spark-- if it did not start with the starting fluid, pull a plug
wire and hold it about 1/4" from the engine block. have the other
half of your new family crank the engine for at least three revo-
lutions and look for a sharp blue spark.
report back with findings and we'll go from there:repair:
--Shorty
P.S. congradulations on the wedding
Strictly.Offroad
Okay so I now relaced the battery, checked the fuel lines, pump, and filter. Checked and tested both thr alt. And starter. Still turns over but no start. Also checked plugs, cap and rotor. All good. No start. Help please. Needed to have it running today so I can get to work. I borrowed a car for today but no such luck tomorrow.
Lodi Jim
NAXJA Member # 1537
What 89xj said..... check your cps. When you first turn key to "on" position, do you hear the fuel pump run for 3 seconds? Pull the distributor wire at the cap and put a phillips screwdriver in the line to place next to ground and have the new misses turn the starter over while looking for a BLUE spark going to ground. Plug and unplug the CPS connector after carefully inspecting the wire for meltdown and abrasion.
RyanM
pull the wire off the top of the Dis cap that comes from the coil. Stick a screwdriver in it and ground it to the top of ac compressor bolt. got spark?
edit. Lodi already said it. Also do a search on Ballist Resistor
Strictly.Offroad
Thanks for the help and advice. The fuel pump does run. Do you guys know of anyway for me to test it alone? My wifey works super long hours and I'd love to get it started asap. Will check the cps wires and connector when I get back to the house.
Strictly.Offroad
So I unplugged the cps and tested it. It is bad. I have a replacement on hold at baxters that ill pick up tomorrow. Should my truck start with it unplugged. If so, then something else is also wrong.
Strictly.Offroad
More help needed.
RyanM
are you getting spark from coil? If the cks is good, and no spark, a bad coil is likely
Shorty
no.
the signal from CPS is what it used by computer to allow the coil to build, saturate, and collapse to make a spark.
