I've finally found a weekend I like, changed the oil, started on the Parking Brake 1st. I stopped using the E-Brake a while back because if I applied it, it would stick on. Well, after getting the reasonably new rotor off, all I see is rust and burnt broken liner. I removed the shoes, springs, etc, I also pulled the actuator (it hooks onto the cable) and found it to be rusted solid. Took the hardware and did a good clean, but now I can't for the life of me, get that actuator back on the *&^%$&**(! cable.
Ideas?
TIA
Ideas?
TIA
