Pattern Check
clydefrog
Ford 8.8 with G2 4.56 gears, new bearings and Detroit Tru-trac.
I think I am going to run it, heel contact a bit much but backlash is already pretty tight at .012 avg. Spec is .011-.016.
Coast side makes my want to add a shim on the pinion but I don't want to throw off my drive side. Thoughts?
clydefrog
I'm actually gonna take your advise on the backlash first. I will decrease it down to .007ish and re-run the pattern. Thanks for the tip.
RWKHausSupply
NAXJA Supporting Vendor
If that is a G2 gear (5 cut) than it should have a .006 engraved in the side of the ring gear, meaning set BL to that. The spec you're referring to is for a OE gear (2 cut)....
You need to tighten BL, and increase depth, as per that pattern and your given current BL...
clydefrog
Ok, much better. I added .003 to the pinion depth (wish I went with .005) and decreased my backlash down to .007 which, from what everyone is telling me, a bit loose. Pinion seems a bit shallow. I did put significant pull or resistance on the ring gear when I spun the pinion but the consistency is a bit off.
Thanks for all the advise. This is my first 8.8 regear. I really wish the Dana products did shims on the outside like ford, makes adjusting backlash a breeze!
That's looking a lot better! MY 8.25 is adjustable by a pre-load/backlash spanner nut, it doesn't get any easier than that.
