fyrfytr1717
Awhile back, I completely redid my cooling system. New hoses, new thermostat, new water pump, new radiator, etc. I have recently developed a coolant leak which has grown progressively worse over the past few days. I'm 95% sure it is leaking from the weep hole on the new GMB water pump that I installed. Pretty frustrating as it was a new (not remanufactured) unit with a 12 month warranty and I 'm at about 14 months right now.
So here's the question... I replaced the water pump just because I was replacing everything else and I figured why not? Despite its outward appearance, when I pulled the factory one (at about 80K miles) it looked brand new on the inside. No corrosion, discoloration, pitting, nothing. It's been sitting in the box that the new one came in for just over a year now. Any reason not to re-use it rather than going out and buying a new one? Would the bearing seals have somehow dried out after being wet for 10 years and then left dry for a year? I don't want to keep throwing cheap replacements at it every year, but I'm also not overly excited about the prospect of dropping $125 on a new OEM one right now either. Thoughts?
