real tech does still exist!
tealcherokee
for the lazy ones
locktup said:
A few weekends ago and decided to build a new rear axle housing. I was getting tired of repairing the factory housing and I didn't want to spend a bunch of money for an after market housing. I ran it for four days with no breakage and no leaks.
BrettM
tealcherokee said:
for the lazy ones
you forgot the money shot
locktup said:
Thanks.
I offset the axle tubes for more ground clearance. I roughly gained over 3/4" on the axle tubes and over 1 1/4" on the bottom of the third housing. There is .120" cleance between the axle tube and the axle shaft. Axle tubes are 3"x.180" DOM.
XJ_ranger
anyone else worry about the weird loading that offsetting the tubes causes? especially with only 3/16" wall tube?
none the less - pretty cool...
CW
I dont see it being a big issue 3/4 of an inch isn't all that much, it's not like the wrap portals cause.
BrettM
as far as suspension stresses, it's the same thing as a portal but to a much lesser degree. his links should handle it just fine and even with leafs it would be the same as a 3/4" lift block.
as for the axle holding up and not bending... it's far more about design than material thickness. he had to use the thin wall tube to get the full benefit of the design, but I would like to see a bit more trussing.
xjj33p3r
NAXJA Member #1108
Seems like a minimal gain for just 3/4" at the axle tubes. Kinda neat tech article, but not really THAT amazing. The trussing he did on the custom housing was very nice though.
BrettM
yeah, I realized later that his clearance claims at the diff didn't make sense and questioned him on it. his numbers for the diff are just the gains from shaving, which I've already done also.
not as cool as it seemed at first, but still a nice jig idea and cool to see someone build there own housing
ArcticXJ
"Home built axlehousing" is a little bit deceiving, considering its a Yota axle. Not a whole lot more to building the housing than there would be to building a giant wrap-around diff cover. All the actual tech is in the drop out 3rd. No worries about gear mesh, runout, backlash, bearing caps and journals being perfectly aligned, balanced, and machined, etc. This is why we've seen this done with Yota axles, 9" axles, and Rockwells a few times now.
Now what I'd REALLY like to see would be someone fab their own 44, 60, 70, or even 80 housing. Talk about a challenge when youre working in thousandth of an inch tolerances.
Not to take away credit from the fabricator though, thats still definitely very cool to think out of the box, and go totally custom. Looks like he did a good job too.
badron
Only 3/4 inch more!
There been times I would have killed for 3/4 inch more. Ho your talking ground clearance
Fairmonco
Itr is a home built housing....not decieving at all......now if he said "homebuilt carrier" then I can see that being decieving.....but either way....nice work...
XJ_ranger
Im thinking of doing this with some sami axles as a way to make lightweight centered differential housings front and rear for a mini baja...
instead of running offset tubes, could using a smaller tube outer diamiter have the same effect and not loose too much strength? We're shooting to have a sub 500lb rig (not including driver)...
Ill have to look into that...
2" .188 wall axle tubes? :D
Maxwell
looks just like the spidertraxs housing for $399.00, whats your time worth?
(everything but the offset notch)(3/4"?)
BrettM
solid axles for mini-baja?
shortxjdoug
do they still have the water section of the course? i would figure a solid in the front would cause problems plowing through the water
