330LICIOUS
this is for non-disco D30 HP.... so i replaced ball joints today on passenger side. while the axle was sitting out, waiting for me to put on the bj's, the gear oil start slowly migrating toward the tube opening, so i kept it from fully leaking by jacking up the housing just a bit more (angled down toward the driver side).... after finishing the install, i slid the axle shaft back into the tube, put all the components back on, and went for a test drive.
when i got home, there's a little bit of oil on the floor and on the lower ball joint. now, i assumed this was residual oil from during the install. however, now i wonder if i need to worry about the seal inside the tube. when i slid the axle shaft back in, it was smooth and the splines connected without any issue from what i could feel.
how likely is it that i messed up the seal, or is that oil i see just from pulling the axle out, during the initial removal?
thanks
thanks
