Vanimal
so i got a front hp d44 for cheap, but unfortunately it's the late 70's version with the cast spring perches with the radius arm setup. So i'm pretty much stuck with retubing it, or sleeving it.
i can get the old tubes out fairly easily, i can cut them off and bore them out on the mill, worse case scenario. but i'm wondering about putting them back on.... i assume it's a press fit, and then rosette welded? how much of a press fit? i assume it's pretty tight. i'm not sure exactly how i can press it in here since my press isnt high enough. i was thinking of maybe heating the housing and using a long large diameter threaded rod and nuts through the center to pull it together. anyone ever try this?
i also have a chevy low pinion pass drop d44 that i was thinking of cutting the tubes off at the pumpkin and pressing into the ford center section, but using the passenger tube on the driver's side, and the driver's side on the passenger side. it appears that the chevy inner c's are symetrical, so i dont see an issue with this, but am i missing something? then i would just use the chevy flat top knuckles and whatnot. i'll have to do some reading to see if i can use the ford hubs and all that crap on the chevy knuckles. i thought i remember reading i could. then i guess i'd just use some waggy inner shafts until i had the coin for alloys.
any tips on removing and installing the tubes would be appreciated, as well as parts interchangability.
