Semi-built cherokee axles-Feeler
x2elite
I have a trussed high pinion Dana 30 with 4.56 gears, ARB locker, WJ knuckles with true DOM/heim joint crossover steering, custom trac bar mount, and trac bar, big brake rotors, and dual piston calipers. I was told that it had chromoly shafts too, but haven't confirmed. Will throw in the compressor and switches for the ARB locker as well.
Matching 8.25 rear, 29 spline, disc brake swap, 4.56 gears, welded, with raised shock mounts.
Also will throw in the set of 1" wheel spacers that are on the axles now.
These are a bolt in swap for any XJ.
I'd like to get $1500 for the set, but feel free to make me an offer.
x2elite
Nope these are gone, but I do have a Dana 44 front, and a semi built 8.8 rear already setup for an XJ for sale now.
