Absolutely correct.Test your temps with a touch-less Infrared Thermometer.
Replace thermostat if needed. If the thermostat works correctly, the fan cannot over-cool the engine,
Yes.Don't have a touch less thermostat. However I do have a thermocouple and a volt meter. What would I measure look at to see the temp? The outside of the housing that the t-stat is in?
Yes and yes. A good T-stat and good working electric heater in the O2 sensor are critical to getting max fuel economy in the winter.Do the non OBD 2 controlled have a open loop and closed loop fuel curve that it followed? Will staying at 160 cause any issue with fuel economy?
